Read csv in SchemaMapper via published parameter
I want to read the csv file for my SchemaMapper via a published parameter. This however does not seems to be an option. I can not select a parameter and when I try to type $(published_parameter), I get in parameters the notification "No dataset found in $(published_parameter)". How can I solve this issue?
PS: using FME 2016.1 build 16492
Best answer by redgeographics
The wizard won't let you do that but once you've set up the whole SchemaMapper you can go into the Navigator and create a user parameter of the source file parameter. Just find it in the list, right-click and choose "Create user parameter"
redgeographics
Forum|alt.badge.img+49
  • May 22, 2017
  • May 22, 2017
Thanks, did not know you could do it like this!
verdoodtdries
Forum|alt.badge.img+18
FYI:
Linking Published / Private parameters in the Navigator pane is a useful workaround.
It is often applicable for Transformers in older versions of FME.
