Read CSV File and split the content into lines and columns
  • Jul 18, 2023 10:06 AM UTC
  • 7 replies
  • 847 views
dataman
Forum|alt.badge.img+7
Hey there,
I have to download several CSV Files from a website. I do it with the HTTPCALLER Transformer. It works perfect. I get ALL the data (several columns and lines) in one "cell":
imageI need the informations in lines and columns, so that I can manipulate the data.
I have tried with Pythoncaller, ListExploder, AttributeCreator,... but it doesn't work.
Do you have any idea, how can I get that? I think the problem is the configuration of the HTTPCALLER or of the other Transformers but I have tried a lot of things and nothing works.
Many thanks in advance!
Best answer by nielsgerrits
Multiple ways:
  • Writing and reading as a file. Will cost some I/O, but is probably the fastest. You can write to temp files to avoid having temp files to clear afterwards using the TempPathnameCreator. This is the way I prefer.
    • Write as CSV using a FeatureWriter.
    • Write as CSV from HTTPCaller.
    • Read written file using a FeatureReader.
  • Splitting the attributes to a list. Create attributes from listelements.
    • Split file to lines based on newline.
    • Split lines to columns based on semicolon.
    • Create attributes from listelements.
nielsgerrits
Forum|alt.badge.img+67
  • Jul 18, 2023 10:29 AM UTC
Multiple ways:
Forum|alt.badge.img+54
  • Jul 18, 2023 11:20 AM UTC
Multiple ways:
No need for the FeatureWriter, you can choose save response body to file instead of attribute in the http caller
nielsgerrits
Multiple ways:
Attached workspace demonstrating this.
dataman
  • Jul 18, 2023 12:58 PM UTC
Hello,
thanks for the answer. If I save the URL as CSV with the featurewriter and after that I read it as featureReader, it goes so fast, that the informations won't be as attribute read... I suppouse that the reader is too fast and the file was not saved
dataman
  • Jul 18, 2023 1:07 PM UTC
Multiple ways:
The second way works perfect. Awesome! thanks
nielsgerrits
You need to expose the attributes manually, or using import.
nielsgerrits
Cheers :)
