RasterResampler output differs from the requested input cell size
  • Feb 8, 2022 3:56 AM UTC
  • 83 views
I am trying to understand why, when using the FME RasterResampler (cell spacing) for multiple datasets at various resolutions, the output is variable resolutions rather than just the cell spacing I have defined (10m).
For example one dataset with a native 2m resolution does not get resampled to 10m when I use the RasterResampler setting cell spacings to 10m, but instead is is resampled to 14.3561626759533. All datasets are resampled slightly differently and only a few to the requested 10m.
What I want is the resample output to be the same as resampling in arcmap, would I need to use a python caller to do that?
daveatsafe
Forum|alt.badge.img+24
  • Feb 8, 2022 6:26 PM UTC
Hi @tiger​,
This is definitely not the expected behavior of the RasterResampler. Would you be able to share a copy of your workspace with us?
  • Feb 8, 2022 8:41 PM UTC
That is good to know daveatsafe, I can't share the workspace publically unfortunately, but I have since discovered that the issue is not with the RasterResampler, but instead lies with the Reprojector which follows the Resampler recalculating the cell size.
