raster resampler and align
  • Apr 1, 2026 2:54 PM UTC
  • 6 replies
  • 165 views
pabloolivaresm
I have a raster with 0.25 m pixel size, I need to resampler to 0.5m and get align with another raster who it’s already in 0.5m pixel size.
I tried many transformer but without succes, and fme helps transformer didn’t help me
Any idea? thanks u!
align
koulsoum
Forum|alt.badge.img+14
  • Apr 2, 2026 2:41 PM UTC
Hello ​@pabloolivaresm
RasterResampler is the transformer that aloud you to resample a raster. If you want to align with the another raster you should have the same tiles (dimensions and perimeter).
daveatsafe
Forum|alt.badge.img+24
  • Apr 2, 2026 6:04 PM UTC
Hi ​@pabloolivaresm, you can use the RasterMosaicker to match an image’s resolution and alignment to a baseline image using the following process:
The RasterMosaicker sets the resolution and alignment by the first image it receives, so the Sorter ensures that the baseline is received first. The image to be adjusted is then added to this mosaic, then it’s boundary is used to clip the resulting image back to the original size.
pabloolivaresm
Hi ​@daveatsafe I tried with this process but I get the pixel values from the reference raster. Maybe it’s the transformer settings that’s not correctly set
daveatsafe
  • Apr 7, 2026 3:09 PM UTC
Please try setting ‘Nodata Overwrites Data’ in the RasterMosaicker to ‘Yes’
pabloolivaresm
I tryed with this setting but I still get the values from reference raster. With ArcGIS and QGIS I was able to do it. Thanks anyway! ​@daveatsafe
daveatsafe
  • Apr 9, 2026 2:50 PM UTC
Try using an Offsetter to move the reference image 1000 meters away before the mosaicking. This should ensure that the clipping step keeps only the adjusted image.
