Quick alternative to StatisticsCalculator?
  • May 16, 2018 3:16 PM UTC
  • 15 replies
  • 213 views
l_d
I'm calling 6 separate StatisticsCalculator transformers, and they each take a (relatively) long time to run. All I'm calculating each time is a min, max and count attribute so this seems like overkill.
Is there an easy alternative I'm missing? Is there a way to use a math function against the entire dataset for example?
erik_jan
Forum|alt.badge.img+26
  • May 16, 2018 4:36 PM UTC
Have a look at the InlineQuerier.
A SQL statement might be easier and quicker.
jdh
Forum|alt.badge.img+41
  • May 16, 2018 4:46 PM UTC
Depending on your data, it might also be quicker to sort on your attribute and sample the first and/or last feature for the min/max.
The quickest way I've found to get a total count attribute is to use the Aggregator (with List) with a count attribute, followed by a deaggregator to restore the original features.
  • May 17, 2018 7:49 AM UTC
If your data source is a SQL database, I think it would be hard to beat the performance of a SQLExecutor with something like:
select
  max(my_value) as my_max,
  min(my_value) as my_min,
  sum(my_value) as my_sum
from
  my_table
where
jdh
  • May 17, 2018 3:17 PM UTC
select
from
  my_table
where
Agreed.  However if the source data in not a database, and is sufficiently large that the StatsCalculator is taking a long time to run, I wonder about the overhead of generating the SQLite database in the InlineQuerier.
jdh
  • May 17, 2018 3:34 PM UTC
I changed my mind, the quickest way to get a total feature count for medium sized datasets is via python.  (10% more efficient than aggregator/deaggregator w/ 10000 features)
class FeatureProcessor(object):
    def __init__(self):
        self.Total = 0
        self.Features=[]
    def input(self,feature):
        self.Total+=1
        self.Features.append(feature)
    def close(self):
        for feature in self.Features:
            feature.setAttribute("TotalCount", self.Total)
            self.pyoutput(feature)
I haven't done any benchmarking for large or complex datasets (lots of attributes, heavy geometry)
fmelizard
Forum|alt.badge.img+22
  • May 18, 2018 2:45 AM UTC
I suspect that if you have a large amount of data, the InlineQuerier overhead may not be too bad compared to doing 6 stats calcs one after the other. WHen you set up the InlineQuerier, just be sure to only define the columns you will want to do the select against to speed things even more.
  • May 18, 2018 6:32 AM UTC
Hi @ld, before thinking of an alternative, I'd like to know why you need to use 6 StatisticsCalculators. If you intend to perform statistics calculation simultaneously on 6 attributes in the same feature type, just a single StatisticsCalculator would be enough.
l_d
  • May 18, 2018 7:04 AM UTC
Hi, they're all operating on separate datasets at different stages of the workbench. Believe me I would put them all through the same transformer if that were an option!
l_d
  • May 18, 2018 7:05 AM UTC
select
from
  my_table
where
Hi, the input data is a .dwg and an XML.
l_d
  • May 18, 2018 7:06 AM UTC
    def __init__(self):
        self.Total = 0
        self.Features=[]
        self.Total+=1
    def close(self):
Thank you, why didn't I think of Python? I will try this.
  • May 18, 2018 7:57 AM UTC
I got it. As other experts suggested, the InlineQuerior or the PythonCaller would be a good solution.
I provide another way. If you are using FME 2018.0, you can use the Sampler (sampling the last 1 feature) effectively to do that. This custom transformer implementation might be useful.
quick-statisticscalculator.fmw (FME 2018.0.0.3)
  • May 18, 2018 8:24 AM UTC
Updated to add the source attribute name as prefix to the resulting attribute names.
quick-statisticscalculator-2.fmw (FME 2018.0.0.3)
l_d
  • May 18, 2018 8:55 AM UTC
Thanks @takashi, I'm stuck with 2017.1 for a little while longer but will look at this when our organisation updates to 2018.
jdh
  • May 18, 2018 1:48 PM UTC
It should be fairly simple to adapt this to also check max min values for any number of attributes.
The above code assumes that you want the values added to every feature, if you just want a summary feature instead, then you don't need to build the feature list, and can just output a single feature in the close method. This will be a lot more efficient, since all the features do not need to be stored in memory.
jdh
  • May 18, 2018 2:11 PM UTC
That's a nice, efficient way of getting a summary feature.
