Querying multiple fields in a single table
  • Jul 3, 2022 7:01 PM UTC
  • 5 replies
  • 72 views
sudhakary
Forum|alt.badge.img+3
Hi Community,
Based on the Figure 1 table, two fields exist as mentioned and I want to find the results as mentioned in Figure 2
I tried so many transformers and had no luck.
Figure 1
imageFigure 2
Figure 2Please help me with how to get the results.
danilo_fme
Forum|alt.badge.img+58
  • Jul 3, 2022 8:53 PM UTC
Hi @sudhakary​
I simulated your case - Steps bellow:
  • Reading the excel file
  • Split the first position attribute (ID1) - AttributeSpliter
  • Using condition of search - Tester
Print_WorkspaceI attached the Workspace template (.fmwt).
Thanks in Advance,
Danilo
danilo_fme
  • Jul 3, 2022 8:55 PM UTC
Hi @sudhakary​
Thanks in Advance,
Danilo
The results:
Results
sudhakary
  • Jul 4, 2022 3:49 AM UTC
Hi Danili_fme, thanks for your time and resolution.
I will narrate my requirement in detail as below.
In ID1 "111111" are having 4 duplicate values whereas the ID2 values are different for that group, I need to get the 1st record as a result, after this the ID2 "222222" need the 2nd value from ID2, and so on. Here I don't want to match the first character in ID1 and ID2.
@sudhakary​ can you include files instead of images and then we can experiment with the example data?
sudhakary
  • Jul 5, 2022 11:29 AM UTC
@markatsafe, attached is the sample CSV file
