Query table names (feature_type) when importing database?
  • September 23, 2022
  • 6 replies
  • 41 views
aron
Forum|alt.badge.img+16
I have a Geopackage with lots of tables and would like to speed things up by only reading the needed tables for later processing. The 'Where' field only applies to table content, I want to filter on table names. I would like to use a wildcard to import layers containing a certain string.
Example
In a dataset all hydrographic layers might contain the string 'hydro'
I would like to use sql to only import these layers by using something similar to 'LIKE %hydro%'
edited by including an example
Edit 2: I realise I made a huge, and embarrassing, typo. The file I am working with is a geopackage, not a gml... *facepalm*
carmijo
Forum|alt.badge.img+11
Hi @aron​, Is this helpful?
aron
Thanks, but not really what I was after. I would like to use a wildcard to select layers containing a certain string.
Example
carmijo
Example
I see. Hopefully someone more familiar with GML can step in and help. Good luck!
  • September 26, 2022
@aron​ GML is not a queryable database and doesn't support SQL. Also, XML doesn't dictate the order of records so FME generally has to read the entire dataset and then pick that apart. Here's a starting point for working with XML/GML in FME: https://community.safe.com/s/article/inspire-gml-reading-writing-and-validation-basics
If you're able to attach a sample of your data then someone might be able to give you an optimized approach to reading your GML
aron
  • September 27, 2022
@Mark Stoakes​ I realise I made a huge, and embarrassing, typo. The file I am working with is a geopackage, not a gml... *facepalm* Maybe I should just start over with a new question.
@aron​ You have two options.
  1. When you add the reader to FME, just select the "hydro" feature types. If the next geopackage has additional 'hydro' tables, use Import Feature Types and just add them to the workflow. The Select Tables dialog allows you to filter.
  2. Use a dynamic workflow - select Single Merged Feature Type on the Add Reader dialog. This will allow you to ender a Merge Filter where you could use *hydro* or something to read only the 'hydro' tables
