PYTHONEHOME for FME Server
  • Apr 22, 2020 12:26 PM UTC
  • 256 views
I´m currently setting up a custom Python interpreter for FME Server 2020.0
I have installed a custom Pyhon installation and added a packge to it.
I´ve also runned the following commands with administrator privileges in command prompt:
"C:/Program Files/FMEServer/Server/fme/fme.exe" APPLY_SETTINGS SYSTEM "Python/Use Custom Python" true
"C:/Program Files/FMEServer/Server/fme/fme.exe" APPLY_SETTINGS SYSTEM "Python/Python Interpreter" "path_to_pyhon_folder/python37.dll"
When I run my workspace that uses Python I get:
The PYTHONHOME for the user-specified Python interpreter is not set through FME Options or a PYTHONHOME environment variable.
On my local computer I can set the PYTHONHOME-parameter under Tools-FME Options...
But what is the command to set this parameter on FME-Server?
The documention only covers the two commands I've already runed.
  • Apr 22, 2020 12:32 PM UTC
You have to set PYTHONHOME in the system environment variables, e.g.: https://docs.oracle.com/en/database/oracle/r-enterprise/1.5.1/oread/creating-and-modifying-environment-variables-on-windows.html#GUID-DD6F9982-60D5-48F6-8270-A27EC53807D0
It may be necessary to restart the server for the changes to take effect.
  • Apr 22, 2020 12:41 PM UTC
@david_r Thanks for clarification. That was my "to-go-to" if there wasn't any other solution as I wished to avoid a restart of the server. But hey, got to do what it takes.
Thanks for fast response anyway :)
