PythonCaller- How to expose a list that contains several lists from a PythonCaller ?
katt
Forum|alt.badge.img+12
Hello, I am creating a list in a pythonCaller which contains lists inside. Similar to this example: mylist=[[4, 5, 6], [1, 2, 3], [9,8,7], [10,14,13], [5,9,10]]. How can I expose this list to pass it to the next transformer ? The usual way of feature.setAttribute('mylist{}', mylist) is not working. My script is working fine when I am running it outside of FME. I am getting the following error in FME:
"Python Exception <TypeError>: Could not convert attribute value to a supported attribute type.
Error encountered while calling function `processFeature'
PythonCaller_3 (PythonFactory): PythonFactory failed to process feature"
daveatsafe
Forum|alt.badge.img+19
  • July 5, 2023
Hi @katt​,
The setAttribute() method can only handle single layer lists. To work with the nested list you will need to unpack and assign the element individually:
        newFeature = fmeobjects.FMEFeature()
        mylist = [[456], [123], [9,8,7], [10,14,13], [5,9,10]]
        i = 0
        for sublist in mylist:
            j = 0
            for item in sublist:
                newFeature.setAttribute('mylist{' + str(i) + '}.sublist{' + str(j) + '}',item)
                j = j + 1
            i = i + 1
        self.pyoutput(newFeature)
  • July 6, 2023
daveatsafe wrote:
Hi @katt​,
        i = 0
            j = 0
                j = j + 1
            i = i + 1
Slightly more compact and (in my humble opinion) slightly more Pythonic:
mylist = [[456], [123], [987], [101413], [5910]]
for n in range(len(mylist)):
    for m, value in enumerate(mylist[n]):
        feature.setAttribute(f'mylist{{{n}}}.sublist{{{m}}}'value)
You'll have to expose "mylist{}.sublist{}" in your PythonCaller.
Result:
