PythonCaller: download from FTP to specific folder
  • Oct 30, 2024 2:33 PM UTC
  • 169 views
fikusas
Forum|alt.badge.img+5
How can I download file from ftpes:// to specified folder? I’m using the script below.
import fmeobjects
import os
from ftplib import FTP_TLS
import ssl
def processFeature(feature):
path = '/lsms/'
filename = 'apples.zip'
ftp = FTP_TLS('FTP-SERVER')
ftp.ssl_version = ssl.PROTOCOL_TLS
ftp.login('name', 'pass')
ftp.prot_p()
ftp.cwd(path)
ftp.retrbinary("RETR " + filename, open(filename, 'wb').write)
ftp.quit()
feature.setAttribute('name', filename)
  • Oct 30, 2024 2:57 PM UTC
Why not use the FTPCaller?
fikusas
  • Oct 30, 2024 3:12 PM UTC
FTPCaller gives error with no clear info about it. I'm using older version of FME. Trying to work around this.
saraatsafe
Forum|alt.badge.img+13
  • Nov 6, 2024 8:19 PM UTC
Hi @fikusas, what’s the error you’re running into when you try the FTPCaller? It might help to run your workspace with Log Debug enabled, sometimes that can give us a little more information as to what’s gone wrong. You can enable Log Debug by navigating to Tools > FME Options > Translation > Log Settings.
fikusas
  • Nov 7, 2024 9:51 AM UTC
Log shows “Error” without any details about it. Probably its version bug.
