Python version error - what are my options
  • Nov 26, 2019 10:38 PM UTC
  • 139 views
bo
Forum|alt.badge.img+10
I have an old but simple workspace with one private parameter defined as
return FME_MacroValues['pEvent_Attributes'].replace(',',' ') + ' ' + FME_MacroValues['pEvent_Route_ID']
When I dug it up and run it under 2019.1.2.0 (20190829 - Build 19630 - linux-x64), it failed with the following msg:
Python version 3.6 loaded successfully
Traceback (most recent call last):
  File "<string>", line 5, in MF_Include_1574806112377
  File "<string>", line 4, in ParamFunc
KeyError: 'LRS_EventMerger_pEvent_Attributes'
INCLUDE -- failed to evaluate Python script `def ParamFunc():
  return
FME_MacroValues[FME_MacroValues['LRS_EventMerger_WORKSPACE_NAME'] + '_' +
 'pEvent_Route_ID']
value = ParamFunc()
macroName = FME_MacroValues['LRS_EventMerger_WORKSPACE_NAME'] + '_pAttributes_Merge'
if value == None:
  return { macroName : u'' }
else:
  import six
  try:
    value = six.text_type(value)
  except UnicodeDecodeError:
    value = six.text_type(value, 'utf-8')
  return { macroName : value }
Program Terminating
Translation FAILED.
I would like to know how I may fix this with the 3.x Python instead of using Python 2.7  Thanks for any comments.
Bo
sigtill
Forum|alt.badge.img+25
  • Nov 27, 2019 7:55 AM UTC
Have you tried for instance:
https://www.pythonconverter.com/
I`m sure some other Python-entusiasts might give a better answer :)
  • Nov 27, 2019 8:41 AM UTC
The problem is that the dictionary FME_MacroValues does not know of a key called "LRS_EventMerger_pEvent_Attributes", I'm not sure it is tied to the Python version.
Is this inside a custom transformer, perhaps?
bo
  • Nov 27, 2019 3:30 PM UTC
@david_r, you are right. It turned out that the parameter name was changed. This is NOT python related afterall!
