Python using calculateSlope
  • Jun 27, 2021 12:05 PM UTC
  • 6 replies
  • 94 views
jkr_wrk
Forum|alt.badge.img+37
I have very little python knowledge so I have real trouble understanding the documentation FME provides:
http://docs.safe.com/fme/html/fmepython/api/fmeobjects/_rastertools/fmeobjects.FMERasterTools.calculateSlope.html?highlight=rastertools#fmeobjects.FMERasterTools.calculateSlope
I have a PythonCaller that calculates the slope of a Raster. At the end I want to itterate over the cells to calculate the desired height, but for now I want to understand how to use Python to manipulate a raster.
class FeatureProcessor(object):
    def input(self,feature):
            raster = feature.getGeometry()
            rst = fmeobjects.FMERasterTools()
            settings = {'kFME_CalculateSlope_interpolateNodata' : 'No'}
            raster_new = rst.calculateSlope(1,raster,settings)
            feature.setGeometry(raster_new)
This works, except that it still interpolates Nodata. So how should I write down the settings dict to tell the function not to interpolate and use the Horn method?
Best answer by debbiatsafe
Also replying here for greater visibility. The correct syntax for the key kFME_CalculateSlope_interpolateNodata would be:
settings = {fmeobjects.kFME_CalculateSlope_interpolateNodata:'No'}
Note that the key is a constant instead of a literal string.
hkingsbury
Forum|alt.badge.img+73
  • Jun 27, 2021 8:26 PM UTC
Any reason you're doing it this way rather than using some of the inbuilt transformers?
jkr_wrk
  • Jun 28, 2021 9:48 AM UTC
The next step is to itterate over the cells to set a new height, starting from the lowest or highest cell value working up/down. This I can't do effectively with the current tools.
But if I can't get the same results doing this with python and with the slope transformer I will not start the rest of the steps.
hkingsbury
  • Jun 28, 2021 7:49 PM UTC
I'm struggling to understand exactly what you're trying to achieve. For more complex Raster manipulation I have had great success coercer then to pointclouds and using some of the pointcloud transformers. These may be helpful in what you're wanting to achieve?
nielsgerrits
Forum|alt.badge.img+67
I think the question is, what is the correct syntax to set the setting
to
No
because
seems to be not correct.
jkr_wrk
  • Jun 30, 2021 12:55 PM UTC
to
No
because
I have this workbench and expect the same results from the rasterSlopeCalculator as the PythonCaller. But it is not working so I think I don't understand the Python documentation.
The Python_polate_no inspector should have the same result as the Slope_polate_no AND
The Python_polate_yes inspector should have the same result as the Slope_polate_yes
So i'm doing something wrong on line 5 or 6, but I don't know what.
debbiatsafe
Forum|alt.badge.img+24
  • Jul 7, 2021 12:06 AM UTC
