Python function enumerate
  • Aug 23, 2016 9:52 AM UTC
  • 10 replies
  • 98 views
I have a PythonCaller with a script using the unumerate function.
In my Python IDE, it works fine. In my FME project on my laptop either.
But, when I copy it in a FME project on another computer (VM actually), the enumerate line seems to be passed without an error message.
 	finalFieldListOutput = []
        with open('formDataOutput.txt') as myFile:
            logger.logMessageString("2dans le with IIIIIIIIIIIIIIII")
            for number, line in enumerate(myFile, 1):
                logger.logMessageString("2dans le for OOOOOOOOOOOOOOOOO")
                if 'FieldName:' in line:
                    logger.logMessageString("2dans le if FFFFFFFFFFFFFFFF")
In the FME logger, there is just "2dans le with IIIIIIIIIIIIIIII".
In all the situation, I'm using Python 2.7. So I cannot see where is the problem.
Best answer by david_r
I'm guessing that "myFile" is empty on your VM, in which case enumerate() does nothing.
Maybe try logging the contents of "myFile" on line 3 and check:
logger.logMessageString("myFile: " + repr(myFile.readlines()))
  • Aug 23, 2016 10:24 AM UTC
It seems that there is no problem in the script. Did you check whether the source text file actually contains some lines?
  • Aug 23, 2016 10:25 AM UTC
  • Aug 23, 2016 12:40 PM UTC
error message :
TypeError: cannot concatenate 'str' and 'list' objects
and if remove the string, I have :
TypeError: must be string, not list
  • Aug 23, 2016 12:49 PM UTC
Probably specify input file by full path?
  • Aug 23, 2016 12:54 PM UTC
I saw the FME API documentation but, I can't figure out what is the right one.
  • Aug 23, 2016 12:55 PM UTC
Actually, I can't figure it out how to check by the logger.
  • Aug 23, 2016 12:58 PM UTC
error message :
Fixed the typo, should work now
  • Aug 23, 2016 1:16 PM UTC
myFile: []
You all were right...
  • Aug 24, 2016 1:24 AM UTC
Follow David's suggestion.
  • Aug 24, 2016 6:45 AM UTC
Finally it was, indeed, a problem of empty file. The real cause was far among this lines. My FME project is linked to another software of my company. This sogtware was unable to let run a system command. But problem solved. Thanks guys.
