Python Exception: Value Error
I'm fairly new to FME so my apologies if this is a pretty straightforward question. I'm trying to create a GTFS Feed using FME by reformatting data I already have in a excel table. I'm getting an error from a reader and I'm not quite sure where to look, tried reformatting my table data again but no avail. I'm on Workbench 2017.1
Here's the error:
Python Exception <ValueError>: unconverted data remains: 4
Error encountered while calling function `convertDate'
f_95(PythonFactory): PythonFactory failed to process feature
Any help would be much appreciated
Thanks!
Kevin
Best answer by davidrich
Hi
I believe your issue is due to a rouge character "4" in your date data type columns. I would double check that all your date columns are all valid.
If unable to find the issue. change the data type for your date columns into string data type the use FME date converter to find the problem.
Dave
danilo_fme
Forum|alt.badge.img+45
  • January 11, 2019
Hi @kevin_durkee
Could you share us your log file?
Thanks,
Danilo
Here's the Logfile
logfile.pdf
debbiatsafe
Forum|alt.badge.img+20
  • January 11, 2019
kevin_durkee wrote:
Here's the Logfile
logfile.pdf
Hi @kevin_durkee
Thanks for the log file, would it be possible to provide a small sample your Excel dataset as well as your workspace? That may help in narrowing down the issue.
  • January 12, 2019
Hi
Dave
davidrich wrote:
Hi
Dave
Thanks Dave, I used the date converter to find that all of the times with a 4 in it were being read incorrectly. After reformatting it worked.
