Python Caller MinMax Problem
  • Nov 20, 2024 10:21 AM UTC
  • 170 views
carstenhpt
I am using a python Caller to determine if a value is in a range of two other values which are read from a csv file.
For Example:  Is SearchValue LMH_HNR_Z in the range of value PTOa and value PTOb? If yes, set the variable Fall = B3, if not set it to B3f.
LMH_HNR_Z = 5, PTOa = 1, PTOb = 10 should return: Fall=3B,
LMH_HNR_Z = 11, PTOa=1, PTOb=10 should return: Fall=3Bf
The Code in this picture is part of a bigger function where I discovered the problem but I narrowed the problematic part down to this. The row where the problem happens is this:
if (min(PTOa, PTOb) <= LMH_HNR_Z <= max(PTOa, PTOb)):
What happens is, that this request randomly returns false even if the search value LMH_HNR_Z is in the range of PTOa and PTOb. The output of some tested values and ranges is also visible in the lower part of this post. I can’t really see a pattern there, maybe one of you?
Is someone aware of a bug that causes this behavior? I am using FME Data Interoperability, FME(R) 2022.2.1.0 (20221202 - Build 22776 - WIN64)
 Thanks in advance.
Here is the Code I#m using in the PythonCaller:
import fme
import fmeobjects
import re
# Template Class Interface:
# When using this class, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
class FeatureProcessor(object):
def __init__(self):
pass
def input(self,feature):
print('Starte Python-Falluntersuchung für Bereich 1')
LMH_HNR_Z = feature.getAttribute('LMH_HNR_Nr')
#PTO = feature.getAttribute('PTO_schriftinhalt')
PTOa = feature.getAttribute('PTO_schriftinhalt_A')
PTOb = feature.getAttribute('PTO_schriftinhalt_B')
print('PTOa: ', PTOa)
print('PTOb: ', PTOb)
print('LMH_HNR_Z:',LMH_HNR_Z)
print('Minab: ',min(PTOa, PTOb))
print('Maxab: ',max(PTOa, PTOb))
print('LMH_HNR_Z_ok:',LMH_HNR_Z)
feature.setAttribute("Fall",'B3')
print('FOUND B3')
else:
feature.setAttribute("Fall",'B3f')
print('LMH_HNR_Z_fehler:',LMH_HNR_Z)
print('FOUND B3f')
self.pyoutput(feature)
def close(self):
pass
Example Output:
LMH_hausnummer;  PTO_schriftinhalt;  PTO_schriftinhalt_A;  PTO_schriftinhalt_B
2    1-10    2        B3f    1    10
2    1-11    2        B3f    1    11
2    1-12    2        B3f    1    12
2    1-13    2        B3f    1    13
2    1-14    2        B3f    1    14
2    1-15    2        B3f    1    15
2    1-16    2        B3f    1    16
2    1-17    2        B3f    1    17
2    1-18    2        B3f    1    18
2    1-19    2        B3f    1    19
2    1-20    2        B3    1    20
3    1-20    3        B3f    1    20
4    1-20    4        B3f    1    20
5    1-20    5        B3f    1    20
6    1-20    6        B3f    1    20
7    1-20    7        B3f    1    20
8    1-20    8        B3f    1    20
9    1-20    9        B3f    1    20
10    1-20    10        B3    1    20
11    1-20    11        B3    1    20
12    1-20    12        B3    1    20
13    1-20    13        B3    1    20
19    10-20    19        B3    10    20
19    11-20    19        B3    11    20
19    12-20    19        B3    12    20
19    13-20    19        B3    13    20
19    14-20    19        B3    14    20
19    15-20    19        B3    15    20
19    16-20    19        B3    16    20
19    17-20    19        B3    17    20
19    18-20    19        B3    18    20
11    10-20    11        B3    10    20
12    11-20    12        B3    11    20
13    12-20    13        B3    12    20
14    13-20    14        B3    13    20
15    14-20    15        B3    14    20
16    15-20    16        B3    15    20
17    16-20    17        B3    16    20
18    17-20    18        B3    17    20
5    7-2    5        B3    7    2
6    1-12    6        B3f    1    12
3    1-5    3        B3    1    5
7    1-10    7        B3f    1    10
8    1-11    8        B3f    1    11
9    1-12    9        B3f    1    12
2    1-5    2        B3    1    5
Best answer by david_r
Indeed, I also suspect a data type issue. Try explicitely casting the attributes to int in your Python script before doing any numerical operations on them, e.g.
PTOa = int(feature.getAttribute('PTO_schriftinhalt_A'))
Just be aware that this will throw and exception if the referenced attribute contains an invalid integer, or is empty/missing.
Forum|alt.badge.img+54
  • Nov 20, 2024 10:53 AM UTC
I would check the datatypes of the attributes you are using and force to int if necessary. I think I’ve seen something similar before where the data types were strings and so the comparison wasn’t working as expected
If you look at your first example
5,1 & 10 sorted alphabetically would be 1,10,5 so 5 is not between 1 and 10
  • Nov 21, 2024 12:22 PM UTC
carstenhpt
  • Nov 22, 2024 9:22 AM UTC
Hello together,
indeed it worked like proposed!!!
Thank you for your help, I was not getting further on this alone.
Carsten
