Publish to multiple FME servers
  • Jul 21, 2014 9:07 AM UTC
  • 41 views
Hello,
I need to publish my workbenches to multiple environments.
- Do I need to publish to separate servers?
-Is there a way by which we can publish to multiple servers
-Is there any better way to achieve this
Regards,
Best answer by mark
Hi JohnG
I'm thinking you don't necessarily need multiple servers. You could set up a single server with engines on different environments. Then you publish the workspace once and when you run it add a flag that tells FME Server which engine to run it on.
The FME Knowledgebase should have quite a bit of info on this topic (http://fmepedia.safe.com/KnowledgeOverview) and if not you can contact our support team directly (http://www.safe.com/support) to get in touch with a Server expert,
Hope this helps
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc
mark
  • Jul 22, 2014 4:07 PM UTC
Hi JohnG
Hope this helps
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc
