Public parameter 'File/Folder/URL' inside a GroupBox, published app.
  • Dec 12, 2023 1:12 PM UTC
  • 92 views
kidega
Forum|alt.badge.img+9
When using a 'File/Folder/URL' public parameter inside a GroupBox with Conditional Visibility of the user parameters, it doesn't seem to enable file upload within a published FlowApp. When you're editing the Workspace App in Flow the expected behaviour is working with a display window which allows you to upload a file. Also when running the workspace in Flow it works. Only doesn't work in a published app.
Is this a known issue of FME Flow 2023.1.2 and Form 2023.1.2.0?
Previous post and reply by Kelvin Jenkins seem to highlight this.
Thanks.
Best answer by david_r
For known issues, you may want to check here first: https://community.safe.com/s/article/Known-Issues-in-FME-2023-x
Could it perhaps be related to FMEFLOW-21415 ?
  • Dec 12, 2023 1:24 PM UTC
kidega
  • Dec 12, 2023 2:25 PM UTC
Thanks for the link and notice @david_r​. Yes it is related to that issue ID.
