Projectwise transformers gets 'NoneType' object has no attribute 'encode' error on upload
  • Jun 9, 2021 1:04 PM UTC
  • 11 replies
  • 241 views
roman1
Forum|alt.badge.img+3
The WSG transformer gets following error when I try to upload files to Projectwise:
ProjectWiseWSGConnector: Uploading file "testfile.shp" to Bentley ProjectWise
Python Exception <AttributeError>: 'NoneType' object has no attribute 'encode'
Traceback (most recent call last):
  File "webserviceconnectorfactory\webserviceconnectorfactory.py", line 227, in input
  File "webserviceconnectorfactory\webserviceconnectorfactory.py", line 1129, in _handleException
  File "webserviceconnectorfactory\webserviceconnectorfactory.py", line 200, in input
  File "webserviceconnectorfactory\webserviceconnectorfactory.py", line 467, in _doUpload
  File "webserviceconnectorfactory\webserviceconnectorfactory.py", line 511, in _uploadFile
  File "bentleyprojectwiseconnector\bentleyProjectWiseConnector.py", line 320, in uploadData
  File "bentleyprojectwiseconnector\bentleyProjectWiseConnector.py", line 282, in _uploadNewData
  File "bentleyprojectwiseconnector\bentleyProjectWiseConnector.py", line 233, in _uploadDataBlock
  File "webserviceconnector\webserviceconnector.py", line 565, in addToHeader
AttributeError: 'NoneType' object has no attribute 'encode'
Error encountered while calling method `input'
ProjectWise_-_Upload_New_files_CALLER (PythonFactory): PythonFactory failed to process feature
ProjectWise_-_Upload_New_files_CALLER (PythonFactory): A fatal error has occurred. Check the logfile above for details
Error seems to originate in upload routine. From what I can see it expects a string variable that is null and cannot decode character decoding?.
Currently on FME 2021.0.0.1
Same error happens on FME server 2021.0.0.3
Best answer by jovitaatsafe
Hi @luka_muna​,
I'm happy to report that this has been resolved by the development team for FME 2021.2 (build 21707 and higher). This issue had been caused by the mimetype not being recognized, so in the fixed build, the connector will now successfully upload the file and log a warning.
Please give this another try in FME 2021.2 and newer and it should work successfully now.
  • Jun 9, 2021 1:20 PM UTC
Can you post a screenshot of the ProjectWiseWSGConnector settings?
roman1
  • Jun 9, 2021 1:23 PM UTC
2021-06-09 15_22_13-Window Sure thing
  • Jun 9, 2021 1:29 PM UTC
I'm assuming the Object ID refers to a folder and not a file?
Also, which Python version is specified in the Workspace settings? Have you tried both version 2.7 and 3.x?
roman1
  • Jun 9, 2021 1:36 PM UTC
Object ID is an output variable that refers to Projectwise ID for the file once uploaded. I haven't tryed switching python versions. I'm currently running Python 3.8+.
As suggesed I tested Python versions :
  • 2.7 and 3 (Did not work, same error)
  • 3.7+ (Did not work, same error)
  • 3.6+ (Did not work, same error)
  • 2.7 (deprecated) (Did not work, same error)
  • Jun 9, 2021 1:45 PM UTC
I ought to be clearer, I was referring to the value "Project Object ID" under ProjectWise Destination, not the output attribute.
roman1
  • Jun 9, 2021 2:30 PM UTC
Ah, my bad. Yes it refers to folder i Projectwise.
  • May 11, 2022 6:31 AM UTC
I'm getting the same error. Did you find a solution for it?
roman1
  • May 11, 2022 8:22 AM UTC
Not yet unfortunetly, had to implement a manual workaround
  • Jun 14, 2022 4:20 AM UTC
I was able to upload xlsx and dwg files but couldn't upload dgn files.
ProjectWiseWSGConnector: Uploading file "xxxxxxxxxxxxxxxxxxxxxxxxxxx.dgn" to Bentley ProjectWise
File "webserviceconnectorfactory\\webserviceconnectorfactory.py", line 227, in input
File "webserviceconnectorfactory\\webserviceconnectorfactory.py", line 1129, in _handleException
File "webserviceconnectorfactory\\webserviceconnectorfactory.py", line 200, in input
File "webserviceconnectorfactory\\webserviceconnectorfactory.py", line 467, in _doUpload
File "webserviceconnectorfactory\\webserviceconnectorfactory.py", line 511, in _uploadFile
File "bentleyprojectwiseconnector\\bentleyProjectWiseConnector.py", line 320, in uploadData
File "bentleyprojectwiseconnector\\bentleyProjectWiseConnector.py", line 282, in _uploadNewData
File "bentleyprojectwiseconnector\\bentleyProjectWiseConnector.py", line 233, in _uploadDataBlock
File "webserviceconnector\\webserviceconnector.py", line 565, in addToHeader
ProjectWiseWSGConnector_CALLER (PythonFactory): PythonFactory failed to process feature
ProjectWiseWSGConnector_CALLER (PythonFactory): A fatal error has occurred. Check the logfile above for details
jovitaatsafe
Forum|alt.badge.img+11
  • Jun 20, 2022 10:43 PM UTC
Hi @luka_muna​,
pauldowlling
Forum|alt.badge.img+5
  • Feb 29, 2024 4:17 AM UTC
I’m getting the same error in 2021.2
Any progress?
