projectwise can uprev version metadata attribute in projectwise
  • Feb 16, 2026 10:23 PM UTC
  • 39 views
couch
Forum|alt.badge.img+7
Hi I am using projectwise wgs connector to upload a file into pw. I was wondering if their a way to uprev the version metadata attribute within pw. When the file is uploaded to pw.
saraatsafe
Forum|alt.badge.img+13
  • Feb 19, 2026 12:12 AM UTC
Hi ​@couch,
Could you kindly clarify what you mean? Are you hoping to see the metadata of the file(s) you’re uploading to ProjectWise, in FME?
You can try the List action in the ProjectWiseWSGConnector, which will provide you with some metadata of your items in ProjectWise. Aside from that, you could possibly extract some metadata from the logfile, depending on what you’re after.
