Problem with ListExploder with Version FME Desktop 2022.2
  • Jan 15, 2023 9:58 AM UTC
  • 118 views
I've got a problem with the ListExploder. I am trying to divide a well-formed XML based on a XML-tag. This itself works fine, but the problem is, that all Object, wich get rejected lose there geometry information. I can see it in the DataInspector, the Min and Max Extent shows "nan". Leaving out the ListExploder, the geometry is visualized, so it seems clear, that the objects loose their information at the <Rejected>-Output-Port of the ListExploder.
This problem appears since we installed FME Desktop 2022.2. I tried the same workflow with an older version (2020.1.3.0) and there it works as expected. I put on a screenshot to clarify the situation in FME 2022.
Does anyone know about this problem? Any solution would be helpful.
Thanks in advance and greetings,
André
danilo_fme
Forum|alt.badge.img+58
  • Jan 15, 2023 12:31 PM UTC
Hi @andre00000​
Please, could you share your data?
Thanks in Advance,
Danilo
