Problem with dissolver
  • Feb 14, 2018 4:21 PM UTC
  • 6 replies
  • 112 views
geo-x
Dear FME users.
I maked a buffer with Bufferer transformer with a group by ID but it doesn't work on all lines.
So I tried to dissolve my buffer with Dissolver but I've the same result like you see on this draw :
(Blue : My original 10 buffers - Red : My result)
I give you a workbench example :
Do you know how I can't d othat correctly ?
Thank you for your help.
erik_jan
Forum|alt.badge.img+26
  • Feb 14, 2018 4:45 PM UTC
Looks like the line has a gap and that will result in multiple buffers that can not be dissolved.
If needed you can close the gap using a Snapper first.
austinh
Forum|alt.badge.img+4
  • Feb 14, 2018 4:51 PM UTC
In your Dissolver Parameters, change the 'Accumulation Mode' = 'Merge Incoming Attribute'
geo-x
  • Feb 15, 2018 8:00 AM UTC
Thank you @austinh but it doesn't work
geo-x
  • Feb 15, 2018 8:15 AM UTC
Good that's works ! Thank you !
geo-x
  • Feb 15, 2018 1:46 PM UTC
According to the configuration I can have some different results. Maybe that's works and myabe that doesn't work. This technic is not really reliable in my case.
geo-x
  • Feb 15, 2018 1:53 PM UTC
An example of a dissolver who doesn't work Snapper with before workbench-exemple.zip
