Problem with creating fmetemp file
  • Nov 9, 2023 2:36 PM UTC
  • 5 replies
  • 73 views
I want to read a Geopackage file, but when I run the FeatureReader transformer, it creates a new geopackage file with the name of "file name"_0.gpkg so as cannot be located. I cleared several times my temp folder with ClearTemp.cmd, also Purge temporary files in my FME-script. But still I have problem with temp-file! Can you guide me how can I fix the problem? Thanks
I can read my file via Reader and there is not any problem, but when I read it via FeatureReader, I have problem with temp file!
hkingsbury
Forum|alt.badge.img+73
  • Nov 9, 2023 7:13 PM UTC
It sounds like you haven't set your FeatureReader up correctly. Are you trying to dynamically create the path to read? or is it going to read the same gpkg each time?
  • Nov 10, 2023 8:55 AM UTC
The gpkg is read true a link from the land surveyor organisation, so it is the same data each time, and if it is changed we must request a new link for downloading data.
hkingsbury
  • Nov 12, 2023 7:17 PM UTC
Is the FeatureReader setup the same as the Reader? Can you share the configuration of the Reader (that works) and the FeatureReader?
Can you also share the part of the logfile where the error occurs?
  • Nov 13, 2023 10:51 AM UTC
Yes, they have same parameters setting. My FeatureReader seem as here:
imageAnd shows this error:
imageAnd when I use Reader, I also must add SchemaScanner at can read both data and schema. In this case I don't have any error: imageIn both transformer, I have OGC GeoPackage format and the same link for Dataset.
hkingsbury
  • Nov 13, 2023 8:47 PM UTC
What happens if you run the workspace with the FeatureReader without featurecaching on?
