Problem attaching textures to surfaces in FBX file using AppearanceSetter
  • Apr 5, 2020 3:41 PM UTC
  • 153 views
eric_armitage
Forum|alt.badge.img+11
I have a problem using the appearance setter to apply JPEG textures to surfaces and outputting to FBX file (for input to Unity) using the attached workspace. The files appear to write out ok and I can see the textures applied in the Inspectors. But when I read the new FBX files there are no textures and I get this warning in the log. Any idea how to fix this?
"FBX_2: A texture used by mesh in node '' references a UV set named 'default', which doesn't exist"
gio
Forum|alt.badge.img+15
  • Apr 6, 2020 10:15 AM UTC
@eric_armitage
You might want to save the workspace as a template (safe as template) so as to include the relevant files.
eric_armitage
  • Apr 7, 2020 8:31 AM UTC
@eric_armitage
Hi
Unfortunately the files being read are too big to attach. But can be downloaded from here
https://www.opendata.dk/city-of-aarhus/3-d-bymodel-aarhus-kommune-bygninger
