Problem
  • Feb 23, 2022 5:21 PM UTC
  • 39 views
I installed FME server 2021.2.2 and I have a problem in the gestion of the coordinates system NTF.Lambert-2E-ClarkIGN. It seems that FME server doesn't recognized this coordinates system and thinks it's NTF.Lambert-2C-ClarkIGN.
We tested with FME desktop 2021.2.2 and FME server 2021.2.3 and the coordinates system is recognized. Do you know if there is a problem with FME server 2021.2.2 and the coordinates system NTF.Lambert-2E-ClarkIGN ?
daveatsafe
Forum|alt.badge.img+24
  • Feb 23, 2022 10:38 PM UTC
Hi @thib_petiet​,
The coordinate systems NTF.Lambert-2E-ClrkIGN and NTF.Lambert-2C-ClrkIGN are almost exactly the same, with the exception of the lat/long limits, and are mapped to the same EPSG number. If you are reading from a format where the EPSG number is used to provide the coordinate system, FME will choose the first coordinate system mapped to EPSG:27572, which is NTF.Lambert-2C-ClrkIGN.
