Print the whole Workbench on one page
  • Oct 18, 2016 8:08 AM UTC
  • 195 views
ahmad_saleh
When I try to create print my workbench to a PDF it does not scale the layout in one page, but prints multiple pages. I have chosen to print on A0 form the page setup, but it seems that FME prints A4 size on an A0 page, and creates A4 layouts on an A0 page!
How to print on the whole bench on one page? I read that the FME 2017 have improved print control! So I have downloaded the beta version, but it seems that it faces the same issue.
Regards,
Ahmad
Best answer by silvo
Oh, it looks like a little bit tricky. Try out this way:
  • use the "Page Preview" in Data-Menu
  • First choose a real large Format Printer and set it up to your page size
  • refresh the preview by clicking Portrait/Landscape
  • now the preview looks correct
  • change the printer to your PDF-Printer and print it out
Check it out. It's not the direct one, but for me it works fine.
Best regards!
  • Oct 18, 2016 10:03 AM UTC
Best regards!
fmelizard
Forum|alt.badge.img+22
  • Oct 18, 2016 1:50 PM UTC
If you have build 17169 or later, and you choose "Print" from the File menu in workbench, you'll be thrown into a customized "Print Preview" type dialog. The second rightmost toolbar button will let you pick the paper size, and the zoom slider will allow you to adjust the scale of your workspace on the page.There's even a "fit to page" button on the toolbar by the zoom slider. Then to finally print, you hit the leftmost toolbar button.
I just checked and www.safe.com/beta has 17169 available for Win64 and Mac (just not Win32 yet).
Do let us know how it goes.
ahmad_saleh
  • Oct 19, 2016 5:00 AM UTC
Hello,
Deltasafe, Thank you for the input I have the build the Win32 (17160) so I will wait to for the new build to try this new feature.
Silvo, that was a really great idea, for me it worked fine even on 2015.1 and now I can print the bench in one pdf file. thank you so much.
Best Regards,
Ahmad
