Possible TestFilter bug
I am using FME2016 1.0.1 Desktop, and have encountered, on random occasions, a strange occurrence with the TestFilter transformer.
I can't replicate it as it only happens randomly, but sometimes, after I have added a couple of tests into the TestFilter, a yellow right-pointing triangle appears on the top section of the transformer as well as coming out of the TestFilter streams. Whenever this happens, the workbench fails when I try to run it.
I then have to delete the TestFilter and recreate it. Usually the second time it is recreated with just with the yellow triangles coming out of the different streams, as expected.
Is this a bug? Has anyone else experienced this?
Thanks
Best answer by fmelizard
I'd further add that if you see this again, please snap a screenshot and send that in. Sounds like a bug for sure.
gio
Forum|alt.badge.img+15
  • August 7, 2017
sometimes I experience screen refresh artifacts.
I then move the transformer over the screen edge and the artifact disappears.
Might it be one of those?
Thanks Gio, I'll give that a try next time it happens.
danilo_fme
Forum|alt.badge.img+57
Me too @gio . I believe the refresh of screen.
erik_jan
Forum|alt.badge.img+26
  • August 7, 2017
But if it is just a screen refresh issue, it should not cause the workspace to fail!
erik_jan
  • August 7, 2017
If you can reproduce this, I would send it to support@safe.com
You are using FME 2016.1.0.1. But was the workspace created using this version or are you adding the TestFilter to a workspace created with an older version of FME. I have seen cases like this before when an older workspace was edited with a newer version of FME.
fmelizard
Forum|alt.badge.img+22
fmelizard
  • August 8, 2017
gio
  • August 8, 2017
yes, it would not cause a fail I assume, never tested it, but would be pretty illogical ;).
Then I can not say I ever experienced the described behavior in any transformer.
Reproduce and screenshoot it.
Hi @daleatsafe yep sure, next time I see it, I will send a screenshot and send it in. Thanks!
