Polyine Crosses - Cnr of Road A - Road B points
  • Sep 20, 2019 2:40 PM UTC
  • 47 views
timwarfe
Forum|alt.badge.img+10
Hi guys,
I'm trying to create a point table from a Road Polyline Table.
Desired result:-
Point layer where the roads intersect (Cross) with Attributes. (Point Object, Road A, Road B)
Can someone please help me achieve this??
Thanks in advance.
Tim
erik_jan
Forum|alt.badge.img+26
  • Sep 20, 2019 2:58 PM UTC
Have a look at the Intersector transformer. The Node output port will give you what you need.
jdh
Forum|alt.badge.img+41
  • Sep 20, 2019 3:00 PM UTC
The node port of the Intersector with Generate List should give you want you want.
You can use a ListElementCounter/Tester to remove dangle nodes if required.
