Polygon Snap to Line
  • Jan 16, 2019 6:20 AM UTC
  • 94 views
Hello,
I have a polygon layer which I want to snap to the road network. I used the Anchored snapper and given snapping distance 10. But some edges are overshooting. is there any way, polygon will snap to the nearest polyline?
parashari
  • Jan 16, 2019 6:39 AM UTC
How about SmartCleaner and then ChangeDetector simply. I hope snapping to a particular line is not a criterion.
  • Jan 16, 2019 8:12 AM UTC
In cases like this it might be helpful to post one or two screenshots that show what's going on, if possible?
  • Jan 16, 2019 10:33 AM UTC
Hi @hellblazer. I tried smart cleaner and gave the necessary parameter. But the output is coming through the Rejected port.
parashari
  • Jan 16, 2019 10:52 AM UTC
What is the rejection log that you are getting? I agree with @david_r, some screenshots or example data might help for the precise solution.
