Polygon cleanUp
  • Sep 14, 2018 11:46 AM UTC
  • 85 views
boubcher
Forum|alt.badge.img+11
Hello
During the clinging process I get the result below, is there a way we could remove the highlighted line
using FME
Thanks
  • Sep 14, 2018 11:49 AM UTC
Have you tried the SpikeRemover?
danilo_fme
Forum|alt.badge.img+58
  • Sep 14, 2018 11:50 AM UTC
Hi @boubcher
Could you share us a simple your polygon to test?
Thanks,
Danilo
boubcher
  • Sep 14, 2018 8:14 PM UTC
@david_r
Thanks it works with the Spike remover
