Points Distances from a Route
How can I calculate the closest distance from a point to a route?  For example, distances of houses from a tornado path (equivalent to ESRI's Near function).
Thanks ahead for any guidance.
Best answer by takashi
I think NeighborFinder transformer is suitable for your purpose. Connect the point features to BASE port, the route feature to CANDIDATE port of the NeighborFinder. Set a preferable list name to "Close Candidate List Name" parameter of the transformer. Points within the specified maximum distance from the route go to MATCHED port. The points will have a list including the closest distance to the route.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • March 2, 2013
  • March 3, 2013
You should also take a look at the LengthToPointCalculator transformer, it might complement the NeighborFinder, depending on your case.
David
