PointonLine Overlayer - keeping the bit you need
  • Dec 11, 2019 3:24 PM UTC
  • 79 views
I'm using this to cut a line at two specific points per row of data - line a too and from.
The length changes and i get bits on both sides of this line. Is there a simple way to keep the section between the cut points and ignore the rest. The section changes in size for each iteration. Sometimes the largest, sometimes smallest.
thanks
erik_jan
Forum|alt.badge.img+26
  • Dec 11, 2019 3:58 PM UTC
Using the CoordinateExtractor transformer, you can extract the coordinates of the line segments (index 0 = start, index -1 = end) and the points into attributes.
The start and end coordinates of the lines you want should have a matching point object.
You can use the FeatureJoiner transformer to test this.
Hope this helps.
erik_jan
  • Dec 11, 2019 4:01 PM UTC
Another way of doing this is using the "Generate list" on the the line features in the PointonLineOverlayer.
Each line segment that is cut by two points should have 2 list elements.
You can use the ListElementCounter to extract that information and a Tester to filter those line segments with 2 points.
