PointOnAreaOverlayer Transformer rejecting with INVALID_POINT_GEOMETRY_TYPE error
chris_acc
Forum|alt.badge.img+5
Hello,
I am trying to populate a value into "_overlaps" using the PointOnAreaOverlayer Transformer but all the data keeps being Rejected.
This works fine when both Readers are consuming Oracle Spatial but I think the issue may be because my Point data is non-spatial?
Tried the 'Reprojector' Transformer but had no effect. The View with the Point data contains a SHAPE field therefore should contain geometry but the FME non-spatial reader does not contain the field and I cannot pick up the data using a spatial reader.
I may be pursuing the wrong process here?!
Thanks in advance.
Best answer by redgeographics
chris_acc wrote:
The Oracle spatial reader does not pick up the View in the DB when you add into the workbench.
I can add coordinate fields into the View, I assume if I did that I would have to then use a 'VertexCreator' Transformer?
Gotcha. Yes, if you have the x and y coordinates available in the view as fields you can use the VertexCreator to build points.
Forum|alt.badge.img+50
I'm a bit confused: if they should be points and you're using the Oracle non-spatial reader you won't get points, in that case, try the Oracle spatial reader.
chris_acc
  • October 4, 2021
  • October 4, 2021
  • October 4, 2021
@chris_acc​ The Oracle Spatial reader might not see a view in the table list, but if you just type name of the view in the text field it might pick it up
chris_acc
  • October 5, 2021
Unfortunately @Mark Stoakes​ that did not work (on this occasion) but that is good to know for the future.
