point to raster
  • November 7, 2018
  • 6 replies
  • 117 views
fer_ruiz
hi, i read some question from other user. But i don´t read what i need.
from to xml i create vertex and i don´t know what i do to create the raster. i use "imageRasterizer" but i have a error and no create it. is the log file.
gio
Forum|alt.badge.img+15
  • November 7, 2018
@ftl
Did you set a feature color to the vertex? Is required.
fer_ruiz
  • November 7, 2018
@gio . The value what i could use is the value z of each point
  • November 7, 2018
If you need to create a single-band raster based on 3D points, consider using the NumericRasterizer.
gio
  • November 7, 2018
@ftl
ImageRasterizer requires a color value. You can use FeatureColorSetter.
As @takashi said the NumericRasterizer only requires a z value. Should work for you.
Your error log can not be opened by me.
erik_jan
Forum|alt.badge.img+18
  • November 7, 2018
I always think MapnikRasterizer is an easy to use transformer for creating raster from vector (and/or raster).
fer_ruiz
  • November 7, 2018
gio wrote:
@ftl
the zip file is compressed.
