Point on polygon analysis and list all the records under each polygon without merging duplicates
  • Nov 3, 2017 2:41 PM UTC
  • 68 views
Hi, I want to do a point on polygon analysis and list all the records under each polygon without merging duplicate properties.
I’m using Spatial Filter to find the properties within a given area. It’s giving the correct output if I send one record at a time. But when I send all the area records to Spatial Filter it merge duplicate properties (candidates) to a one record.
I’ve change parameters on the Spatial filter but failed to get the expected output. Can someone please help me?
Area record and relevant properties
Area ID Property 1 A 1 B 1 C
Area ID Property 2 C 2 D 2 E
Expected Output
Area ID Property 1 A 1 B 1 C 2 C 2 D 2 E
Expecting 6 properties, not 5 properties after merging the duplicated property C.
Thank you.
Best answer by erik_jan
Have a look at the PointonAreaOverlayer, using the point output port.
Exactly what it is built for.
erik_jan
Forum|alt.badge.img+26
  • Nov 3, 2017 2:54 PM UTC
Forum|alt.badge.img+63
And in addition to @erik_jan's answer: the PointOnAreaOverlayer can create a list, if you then use a ListExploder you'll get your 2 copies for points that fall on the boundary of 2 areas.
  • Nov 6, 2017 5:18 PM UTC
Thank you very much for the replies. By using PointonAreaOverlayer and using ListExploder I've managed to get properties for each area separately.
As I have polygons and points as input I need to make few changes.Probably a buffer for point to make it a area.
