Pivot table and aggregate based on a field
  • Mar 20, 2018 5:57 PM UTC
  • 216 views
I am pivoting a table based on an ID field so that all diagnosis codes are pivoted and grouped based on the ID. Here is an example of source and final tables I am trying to acheive. What transformers will be appropriate to get this done?
stalknecht
Forum|alt.badge.img+22
  • Mar 20, 2018 7:04 PM UTC
I think that you can use an AttributePivoter to get the desired result.
  • Mar 20, 2018 7:11 PM UTC
This is where I am confused with the pivoter: I selected patientID to group rows by but for columns I want to select multiple columns to pivot under a single column named "Diagnosis Codes". I do not see the option to select multiple columns.
stalknecht
  • Mar 21, 2018 8:55 AM UTC
Depending on the datasource you can use a sqlCreator to get an union select query or you can use the inlineQuerier to get the desired result.
See attached template
demo.fmwt
  • Mar 21, 2018 2:21 PM UTC
demo.fmwt
@stalknecht, thanks for your comment. That is exactly what I ended up doing. I am using SQLCreator with Unpivot sql query to transpose from columns to rows.
