pivot table and aggregate
  • May 27, 2020 2:17 PM UTC
  • 75 views
istvanv
Participant
I've been at it for a day, time to ask for some help.
i got the JobHistorySnapshot from FME_SHAREDRESOURCE_DASHBOARD/temp and I am trying to create a custom dashboard and need to pivot some data
The upper table is my input data and the lower is the desired output (i didn't add the other 4 columns for the repo_four)
In words it would go like this, group by date and create columns using repository values concatenated with the existing 4 columns and also transfer the values.
How could i achieve this?
Thanks
raw data
DateRepositoryQueuedTime.MaxTimeQueuedTime.AvgTimeFinishedTime.MaxTimeFinishedTime.AvgTime2020-05-21-17repo_one0088882020-05-21-18repo_one0030292020-05-21-18repo_two2518.511873.752020-05-21-18repo_four11729.252524.52020-05-21-19repo_one004945.52020-05-21-19repo_two2960296024256242562020-05-21-19repo_four0026047260472020-05-21-20repo_one10.16666666712049.833333332020-05-21-20repo_two0024052240522020-05-21-20repo_four002315423154
Best answer by daraghatsafe
Hi @istvanv,
I don't have the exact answer on how to do this but the tutorial below may help you get started on pivot tables and the AttributePivoter Transformer.
https://knowledge.safe.com/articles/31702/pivot-table-using-fme.html
If you try it out let us know how it goes and if there is anything else we can help with.
Daragh
daraghatsafe
  • May 29, 2020 9:24 PM UTC
Hi @istvanv,
Daragh
