Passing parameter containing ampersand
  • January 9, 2024
  • 17 views
sunsilk11
FME Desktop 2021.3
Python Interpreter ESRI ArcGIS Python 3.7
Hi I am trying to pass a user parameter that includes the ampersand
i.e. username@domain, which I then use within a python caller to login to ArcGIS Portal
When I look at the value of the parameter, I get
username<at>domain
hence I am unable to connect to my portal.
I have tried to format using string functions str() and strip(). But it doesn't work
Any suggestions ??
hkingsbury
Forum|alt.badge.img+62
  • January 9, 2024
Hmm, thats weird, I just tried in 2021.1 and 2023.1 (don't have 2021.3) and couldn't replicate it.
However, there is a transformer called DecodeFMEText which will convert that string back into what you're expecting it to be
