Pass and Modify Publish Parameter for Writer clause SQL STATEMENT TO EXECUTE BEFORE/AFTER TRANSLATION
  • Oct 23, 2013 8:12 PM UTC
  • 49 views
Hi all,
I need pass to parameter to my query in SQL STATEMENT TO EXECUTE BEFORE/AFTER TRANSLATION. For example: I am working with GEOMEDIA. I need to standardize the foreing keys names, pk names, sequences names, and insert to GDOSYS (the metadata for geomedia). I am using dynamic schema from readers to writers for all tables(features) in my folder. I need to pass parameters to queries to be executed before and after the writer. How to do?
Regards,
Sólon
fmelizard
Forum|alt.badge.img+22
  • Oct 23, 2013 8:26 PM UTC
I dont think it is possible, you can try running the sql before and after the translation with a sql creator/executor.
  • Oct 24, 2013 10:47 AM UTC
Hi Sólon,
I think it's possible via the Scripted Parameter (Python or Tcl).
If you define two scripted parameters to create Before / After SQL statements based on published parameters, you can link SQL STATEMENT TO EXECUTE BEFORE/AFTER TRANSLATION to them.
Use the following syntax in the script to access a published parameter.
(Python)
FME_MacroValues['parameter_name']
(Tcl)
$FME_MacroValues(parameter_name)
Takashi
  • Nov 13, 2013 3:26 PM UTC
Ok. Resolved.
I solved with WorkspaceRunner.
Thanks All.
