Partial Match on Inline Querier
  • Apr 20, 2021 9:14 PM UTC
  • 5 replies
  • 254 views
Hi, I am trying to perform a LEFT JOIN inside InlineQuerier.
I have two files with similarly named tables, (except for a _).
Inside my TABLE A, in the "CITYCODE" column, I have some values, for example:
"LATAM - RX12345 - SIE0950331501 - Monclova - CITY SERVICE"
On the other hand, in my TABLE B, in the column of "_CITYCODE" with the value "Monclova".
Just like this case, there are thousands more in my tables with the same structure, what I want is to be able to do a LEFT JOIN that partially matches a complete text string containing the values of my column "_CITYCODE".
I have tried to do a LEFT JOIN like this:
select * from "TABLE A"
LEFT JOIN "TABLE B"
on "CITYCODE" like '%'+"_CITYCODE "+'%'
But I don't get the '%' as a wildcard for a partial match.
Could someone help me with this?
  • Apr 20, 2021 10:07 PM UTC
Hi @diello​ , I think you have to:
- use || operator to concatenate strings
- qualify column name with a table name or its alias.
Example:
LEFT JOIN "TABLE B"
on "TABLE A"."CITYCODE" like '%'||"TABLE B"."_CITYCODE"||'%'
or
select * from "TABLE A" as a
LEFT JOIN "TABLE B" as b
on a."CITYCODE" like '%'||b."_CITYCODE"||'%'
  • Apr 20, 2021 11:34 PM UTC
Example:
LEFT JOIN "TABLE B"
or
it works so well.
Perform multiple left joins in a query, could you tell me how to do it?
  • Apr 21, 2021 1:24 AM UTC
@Takashi Iijima​ Hello again, now I have a problem, the _CITYCODE column does not always have data, and many times the field is empty, how could I solve the LEFT JOIN performing it only when it has information?
  • Apr 21, 2021 9:16 AM UTC
A quick way is to insert a Tester before the TABLE B port of the InlineQuerier in order to filter out empty _CITYCODE​.
insert-tester-before-inlinequerier
InlineQuerier uses SQLite as the underlying database. So you have to use SQLite compatible SQL. Great resources on SQLite are SQLite Tutorial & SQL As Understood By SQLite
There are also some tips n' ticks on data joins and InlineQuerier in the webinar Data Integration Basics: Merging & Joining Data
