Parent Directory and subfolders
  • Jul 17, 2018 2:37 PM UTC
  • 7 replies
  • 247 views
I have a set of workspaces inside many directories and a workspace which call all the workspaces one by one using a workspaceRunner.
Here is the picture of my hierarchical structure
In this structure you have a directory called " Livraison - Transformation globale AIXM 51". Inside this one, you have the "master" workspace which call all the workspaces one by one in the various directories you can see on the picture.
Here is the picture of the "master" workspace
The issue i have : when i changed the master directory called "Livraison AIXM 51 V2.0" in another directory, i lost the path of the workspacerunner parameter (show the picture). I would like to use "FME_MF_DIR" and i want to go in the parent directory and go inside the subfolder to reach the various workbenchs, but the absolute paths are used in my case.
Is there a way to use python scripts to :
- Bring in an attribute the value of the "Livraison AIXM 51 V2.0" path
- The main workbench is in "Livraison - Transformation globale AIXM 51". So, FME_MF_DIR contains by default the absolute path of this directory.
- Bring in an attribute the parent directory of FME_MF_DIR
- In each workspacerunner bring the attribute of the subfolders in which the different workbenchs are called
Thanks in advance
  • Jul 17, 2018 3:02 PM UTC
Hi @philippe33, you can get the parent directory path with the FilenamePartExtractor with this setting.
Or, if you prefer to use scripted Python parameter,  try this one.
import os
return os.path.split(os.path.abspath('.'))[0]
  • Jul 17, 2018 3:50 PM UTC
import os
This script is also possible.
import os
return os.path.abspath('..')
  • Jul 18, 2018 8:28 AM UTC
import os
Thank you takashi,
How can i put this result in the workspacerunner transformer in such a way i could retrieve the path of the workspaces i call one by one without having to write them (in the case the absolute path may change) ?
  • Jul 18, 2018 9:25 AM UTC
import os
I thought that you could construct workspace file path within the parameter field using the feature attribute or the scripted parameter, but it wouldn't retrieve published parameters from the child workspace...
Another thought. Probably you can directly set the relative path indicating the child workspace to the FME Workspace parameter field, as in:
..\04 - Transformation Runway 51\010_Test_Gestion_UUID_Runway_gml_id.fmw
  • Jul 18, 2018 9:39 AM UTC
No, it doesn't want to let me do that in this parameter. I try to put an attribute with the creation of a published parameter with the option (script Python). it doesn't succeed. It seems only to accept an absolute path written inside but if i change the path i have to pass inside this workbench and set again the correct path.
  • Jul 18, 2018 9:45 AM UTC
Didn't the parameter field accept any relative path (..\<folder name>\<workspace name>.fmw)?
  • Jul 18, 2018 12:07 PM UTC
I find a workaround to solve my problem, but i don't think it's the good one.
Please see this solution here :
https://knowledge.safe.com/questions/5254/set-workspacerunner-parameters-programmatically.html
How i do the job :
1 - In my main workspace i created a published parameter like this:
The parameter "toto" take the value of the absolute path of the workbench i called in my first workspacerunner
2 - I follow the webpage i gave above
3 - that gives me this following:
When i change the place of the directory "Livraison AIXM 51 V2.0" which is the main directory with all the subdirectories inside, the workbenchs are called with the respect of the new path without having to change the initial workbench.
But i don't think it's the easiest way, but i follow the sample i saw (link above)
