Outfall analysis
  • Feb 19, 2018 5:32 PM UTC
  • 102 views
Has anyone used FME for Outfall analysis?
I have a series of points which represent outfall locations and I need to use the points to follow elevation/DEM to the lowest point on the DEM. Using the path will help me determine what named water body the outfall is effecting.
Using esri tools I have to build the dem with contours or lidar points and then use the hydrology tools to figure out the path of each outfall. I think this is doable in FME, but I am not sure I am using the right terminolgy when googleing this so I thought I would ask the community. Thanks,
Guido
mark2atsafe
Forum|alt.badge.img+59
Hmmm. That's an interesting one. I don't think we have functionality or a transformer designed for that. But I do have an idea to get started...
  • Turn your DEM into points (if it isn't already). If it's raster then the RasterCellCoercer will help.
  • Use a Counter to give an ID to each point
  • Extract the Z values of each point into an attribute (_z)
  • Use the NeighborFinder on each point to locate x neighbors (say 8 for a grid) and create a list
  • Sort the list in order of _z values, descending
Now we can go from point to point, finding the next point from the first entry in the list. Does that make sense?
I suspect you would use a ListIndexer to pull the ID from the first item in the list, then delete the list with an AttributeRemover. Use an Aggregator to merge all points into one feature, with a list of all their "next ID" points.
Then you can use a Loop in a custom transformer to go from your starting point, to the next one, creating a string of ID numbers that form the line.
That's the best I can come up with right now. I can see some issues depending on how good the DEM is (does each point have a neighbor with a lower Z value?) but it's a start.
You might also consider trying R. There's a good shortest-path type tool in there, so it might also have this sort of DEM pathfinding functionality too.
  • Feb 19, 2018 9:38 PM UTC
Interesting approach, I figured there should be a raster or 3d shortest path piece somewhere in FME... I will need to think about this some more. Thanks for your thoughts.
mark2atsafe
I suppose you could turn the DEM into a network of connections, where the cost is related to the fall in elevation, then run it through the ShortestPathFinder. But the ShortestPathFinder needs an end point to go to; it won't start at point X and see where it ends up (be nice if it did).
