OSM Data missing tag
  • Feb 20, 2019 3:37 PM UTC
  • 144 views
jugoslaviaa
Hello,
With help of you, I managed the read the osm transportation data that I have attached. However, I am puzzled with tag information. If I open the data in QGIS, I see other_tags attribute in linestring data. However, I can not see the attribute when I read in FME. I used AttributeExposer but I still am not able see this tag.
I am particularly interested in this tag as it has additional information such as number of lanes,oneway and width etc.
Thanks in advance.
Best answer by david_r
It seems FME is automatically expanding the "other_tags" into (unexposed) attributes. If you e.g. expose the attributes surface, oneway and ref for the first three features in your list, you will see the following in FME, which corresponds to the other_tags list in QGIS:
So basically you'll need to manually expose all the necessary keys for other_tags.
  • Feb 20, 2019 3:58 PM UTC
jugoslaviaa
  • Feb 20, 2019 4:10 PM UTC
You are a life saver! It works. Thank you very much!
