Order of Vertices forming lines and polygons
  • September 16, 2019
  • 148 views
deanhowell
Forum|alt.badge.img+23
Hello All,
I have found a few great posts that helped me get the order of vertices in a polygon but am trying to work out the how to get the start and end coordinates in correct order.
My workflow is as follows:
1. Read in polygon features
2. Use Chopper and counter to break into points and attribute.
3. Use Chopper and counter to break into lines
4. Use PointOnLineOverlayer to get the start and end coordinated.
5. Attribute lines with Start and End point ids.
What I am finding is that the start end end points are correct but the order in the line table is not.
In the example below, I have a triangular parcel where it goes from point 81736 to 81735 to 81750, so I hoping to get something like
1 - 81750 to 81735
2 - 81735 to 81736
3 - 81736 to 81750
but am getting the following
Any assistance would be greatly appreciated.
Here is the workspace that I am working on
Best answer by takashi
Hi @deanhowell, if I understood your requirement correctly, this workflow example might help you.
add-from-to-pointno-to-line-segments.fmw (FME 2019.1.2)
deanhowell
Thanks @takashi, that does the trick perfectly. Thanks for helping me solve another piece of the puzzle.
