Obtaining all attributes with "null" and "0" values from shapefile?
  • August 22, 2017
  • 91 views
Hey guys,
I am trying to build a model which will give me the "null" and "0" count for a number of attributes from my shp. I have built a model using the attribute validator with the Validation Rule "Not Null" to obtain all Null values coming out from the failed output into a statistics calculator transformer where I have "_count" for Total Count Attribute: under Calculate Attributes.
To obtain the "0" values for my other attributes I input my attributes in Attribute Validator and used the validation rule "Contains Regex" with the [0] rule configuration. However this is not the correct was a it will also include subsequent zeros e.g.. "10, 100, 1000 etc."
My questions are; is the above method the correct and most effective way to obtain Null values and how can I use the regex function in the Attribute Validator or any other transformer to obtain "0" values?
Thanks in advance:)!
Best answer by ebygomm
You could also use an attribute creator with a conditional statement to create an attribute with value of 1 for any nulls or zeros and then sum these with a statistics calculator
erik_jan
Forum|alt.badge.img+26
  • August 22, 2017
I believe you should use the regex "^0$".
The ^ indicates the start, the $ indicates the end.
Forum|alt.badge.img+51
  • August 22, 2017
You could amend your regex to ^0$
  • August 22, 2017
