Number Notation
  • November 1, 2016
  • 8 replies
  • 228 views
ccomeau
Forum|alt.badge.img+5
Good morning,
How could I transform a number into French Notation?
Ex: 1000000.00 into 1 000 000,00
This information represents surface area on a map. I have already worked out the calculations and the placement transformers and am stuck on the customer's desired presentation.
Thank you,
Chris
Best answer by takashi
Hi @ccomeau, a PythonCaller with this script might help you.
# PythonCaller Script Example: Format a numeric value in French Notation
# Assuming that the feature has an attribute called "value" storing a numeric value.
# Format the numeric value using comma as thousands separator,
# replace commas with spaces, and then replace the decimal point with a comma.
def processFeature(feature):
    attr = 'value'
    v = float(feature.getAttribute(attr))
    s = '{0:,.2f}'.format(v).replace(',', ' ').replace('.', ',')
    feature.setAttribute(attr, s)
itay
Forum|alt.badge.img+19
  • November 1, 2016
Hi @ccomeau I would look into the StringFormatter for a possible solution.
Hope this helps
itay
  • November 1, 2016
Hi @ccomeau, had a look at the StringFormatter but couldn't get it working so a couple of AttributeSplitters and an AttributeManager did the job.
french-notation.fmw
  • November 1, 2016
    attr = 'value'
  • November 2, 2016
    attr = 'value'
another solution taking advantage of FME String Functions and FME Math Functions.
format-number-with-french-notation.fmw (FME 2016.1.2)
  • November 2, 2016
    attr = 'value'
At first, I thought this script does the trick.
import locale
class FeatureProcessor(object):
    def __init__(self):
        locale.setlocale(locale.LC_NUMERIC, 'French')
    def input(self,feature):
        attr = 'value'
        feature.setAttribute(attr, locale.format_string('%.2f', v, True))
        self.pyoutput(feature)
However, the result is shown like this in my environment - Japanese Windows.
1?000?000,00
I'm curious how the script works in an European locale.
ccomeau
  • November 2, 2016
Good morning,
Thank you both for the quick replies. Your FMWs reminded me that I need to update my licence from 2015.1.0.3 as some transformers are not available.
@itay, the FMW you posted works well with millions but smaller and larger numbers do not format correcly. EX. 235 came out as 2 35 . I would need to split from the right. Perhaps flipping the number around then splitting if, then flipping the lists around would work.
@takashi, I had not thought of using Python. Interesting solution option. Sadly, I am a novice programmer and can't get your first solution working. That being said, your second option using the local settings was a novel solution that did work.
itay
  • November 2, 2016
Good morning,
Hi, true, a remedy would be to test the string lenght beforehand, but that saiud @taskashi 's answer is much more elegant.
  • March 1, 2017
    attr = 'value'
The regex approach provided by @david_r might be a smarter solution. See this link.
Format number from: 1000000 to 1 000.000
