Null values in FME 2014
  • February 11, 2015
  • 51 views
ari
Forum|alt.badge.img+4
Hi all,
I'm working with an FME Desktop 2014 workspace that writes data from a fileGeodatabse to a GML compliant with INSPIRE Address Schema. The process is working but I want to improve the treatment of <null> fields.
More precisely, I would like NOT to write those fields with <null> value.
Is there any transformer that can help me with that ?
So, as an example, now I have this result:
 ... 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator>21</ad:designator> 				<ad:type>addressNumber</ad:type> 			</ad:LocatorDesignator> 		</ad:designator> 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator/> 				<ad:type/> 			</ad:LocatorDesignator> 		</ad:designator> 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator>23</ad:designator> 				<ad:type>addressNumber</ad:type> 			</ad:LocatorDesignator> 		</ad:designator> 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator/> 				<ad:type/> 			</ad:LocatorDesignator> 		</ad:designator> 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator/> 				<ad:type/> 			</ad:LocatorDesignator> 		</ad:designator> 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator>25114</ad:designator> 				<ad:type>postalDeliveryIdentifier</ad:type> 			</ad:LocatorDesignator> 		</ad:designator> 	...
 And, following the previous example, I would like to have this result (i.e: only those files not <null>):
 ... 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator>21</ad:designator> 				<ad:type>addressNumber</ad:type> 			</ad:LocatorDesignator> 		</ad:designator> 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator>23</ad:designator> 				<ad:type>addressNumber</ad:type> 			</ad:LocatorDesignator> 		</ad:designator> 		<ad:designator> 			<ad:LocatorDesignator> 				<ad:designator>25114</ad:designator> 				<ad:type>postalDeliveryIdentifier</ad:type> 			</ad:LocatorDesignator> 		</ad:designator> 	...
Many thanks in advance !
  • February 11, 2015
have you looked at the NullAttributeMapper?
David
ari
  • February 12, 2015
Thanks David for your quick answer !!!
I haven't used before this transformer so now I doing some tests.
Maybe I am doing something wrong but I don't get the expected output.
This is what I have without using NullAttributeMapper
(partial view of GML with FME Data Inspector)
And this the output using the NullAttributeMapper Transformer:
There are only a few registries in designator{2} with data, but designator{5} always contains data. I have defined the following parameters in the transformer:
As far as I understood, ONLY in case that one of the selected attributes is <null> or <empty> will not be written. So, What I'm doing wrong ????
I have try to use the transformer in different places in my workspace but I get the same result.
Many Thanks in advance !
ari
  • February 12, 2015
Sorry about my previous post !
Logger transformer shows that NullAttributeMapper works well
maybe the problem is in the index of designator{}....
A.
ari
  • February 12, 2015
Confirmed! It was a problem with designator{} attribute indexes.
I have solved it with a very little piece of code in pythonCaller.
Thanks again for your inspiration !
