Not all values used in minimum-calculation
  • Apr 12, 2018 2:42 PM UTC
  • 5 replies
  • 120 views
I have a shapefile with multiple float-fields. I want to calculate the minimum value of these fields. For some of the features the calculation is correct, but for some features the values are not used.
I use the AttributeCreator with the Arithmetic Editor:
@min(@Value(BOVENGRENS),@Value(ONDERGRENS),@Value(WINTERPEIL),@Value(VAST_PEIL))
This gives the following result in the field Rekenpeil:
Thank you for your replies!
Best answer by david_r
It's because of the NULL values, the value of min(n,NULL) = NULL, not n.
  • Apr 12, 2018 3:15 PM UTC
  • Apr 13, 2018 4:51 AM UTC
Then why is there a value in the first and fourth row? On those features there are also null values.
  • Apr 13, 2018 8:46 AM UTC
Strange. The min function should return null always if one or more arguments were null. I was not able to reproduce the same situation as yours. Could you please share a minimal data and workspace which reproduce the situation?
  • Apr 13, 2018 8:51 AM UTC
I agree with Takashi, that's indeed unexpected. I wasn't able to reproduce that either.
  • Apr 16, 2018 8:34 AM UTC
I can't send the file, but thanks to your replies I have used a NullAttributeMapper to change the Null values to Empty, which has solved my problem. Thank you!
