no coordinate system from autocad map
  • Jul 20, 2020 5:06 PM UTC
  • 88 views
I am reading in many autocad dwg files. I can extract the coordinates and reproject same. however i need to identify the CS prior to reprojection. These are all Autocad Map drawings with a coordinate system defined for each. the coordinate extractor does not recognize the CS. value is missing.
kailinatsafe
Forum|alt.badge.img+24
Hello @gisbradokla,
Sorry to hear you are having troubles with the coordinate system! Can I ask what version of AutoCad and FME are you using?
Thank you in advance,
Kailin Opaleychuk
2020 map3d/2020.1
I think @daveatsafe is looking at it.
