Network based resource connection issues
  • Mar 22, 2018 3:00 PM UTC
  • 6 replies
  • 519 views
vn1
Forum|alt.badge.img+4
I am trying to utilize a file share within a workbench and establish a network based resource connection on FME Server through the web ui but receiving errors that we have been unable to diagnose. In both uses, the error states "Folder not found" and the location is being referenced by unc path (e.g. \\\\server-name\\folder). The folder in question contains a space, so I have attempted using single quotes and url encoding the unc path with no success. We currently use other file shares within FME Server, and have granted the computers credential (e.g. mango$) read/write access to those resources with success. From the system that runs FME Server, I can verify that other users can access the file share in question, so there doesn't appear to be a firewall issue or other connection related issue. Any help would be appreciated in resolving this issue.
We are currently on FME Server 2017.0.0.1
Best answer by vn1
We ended up resolving this issue. In the initial effort, access was only granted at a subfolder level. The issue was resolved by granting "list folder contents" at the root of the file share \\\\server-name\\drive$
  • Mar 22, 2018 3:29 PM UTC
Are you already running the FME Server engine as a domain user with approriate rights on the share?
If the service is running as local admin, you'll have to reconfigure to use a domain user:
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
vn1
  • Mar 22, 2018 5:37 PM UTC
David, I have read through this and the Directory and Account Permissions and am trying to understand the how it would apply to our environment. Our implementation is Windows Server 2012 R2 and all components are installed and running on a single server. We currently connect to other unc based resources as the local system account for reading and writing data using "server$".
vn1
  • Mar 22, 2018 7:15 PM UTC
  • Mar 23, 2018 8:19 AM UTC
Excellent. Thanks for sharing the solution.
krien
Forum|alt.badge.img+10
  • Dec 4, 2018 1:46 PM UTC
@vn1, @david_r
We (Vicrea) have a customer that had a similar Network Shared Resource issue. After installing FME Server with backup from 2016, the Network Share Shared Resource came up with the error: Path / does not exist for shared resource. All the known issues (domain User, rights on share, Service accounts etc.) checked but no solution found.
I tried to reproduce the issue in our environment by following the tutorials in https://knowledge.safe.com/articles/34522/fme-server-resources-uploading-referencing-and-con-1.html but al worked fine for me.
It was obvious an access problem and I searched in all Fme Server files, both the installation and resources for the MYDATA network shared resource I created.
In the fmesharedresource.log there was no MYDATA, but it showed up in the Safe Software\\FME Server\\resources\\logs\\tomcat\\localhost_access_log_.txt.
After I communicated this with the customer, they found in the \\tomcat\\localhost_access_log_.txt. a 404 error on their shared resource.
Changing the Tomcat Service to run under the Domain Account solved this issue!
Kind regards,
Krien Guijt
  • Dec 5, 2018 8:22 AM UTC
@vn1, @david_r
Kind regards,
Krien Guijt
Hi, thanks a lot for the details, much appreciated!
