My input is contour lines, I want to convert to raster. How can I do this? I was thinking contour->vector->raster, but i am not sure how to convert contour to vector. Any help would be appreciated
Best answer by redgeographics
The contours are probably already vector, so you could use for example an ImageRasterizer or MapnikRasterizer to rasterize them.
Forum|alt.badge.img+50
  • January 20, 2022
I am not sure, looking at my contours they are polylines I think it would be termed. I used both transformers and it was returning errors.
Oh it is working now, I added a featureColorSetter and then the ImageRasterizer and it works! Thank you for the help :)
